Perform the following procedure to configure the PoE power usage threshold limit globally as a percentage on the switch. The switch logs a warning message when a PoE PD power usage exceeds the configured threshold. The switch logs an informational message when a PoE PD power usage is below the configured threshold.
    enable
    configure terminal
  2. Configure the power usage threshold:
    poe poe-power-usage-threshold <1–99>.
The following table defines parameters for the poe-power-usage-threshold command.
Variable
Value
<1–99>
Specifies the PoE usage threshold in the range of 1—99 percent.
